outriger cover
Users of the forum can post details of where to find useful parts here (other than joining the SOC Spares Scheme of course). Note: The Scott Owners Club Ltd does not endorse, recommend or vouch for any of the postings in this section.
outriger cover
Postby ERIC BAYLISS » 07 May 2016, 10:51
Has any one a spare outrigger cover that covers the speedo drive. thanks.
ERIC BAYLISS
Club Member
Re: outriger cover
Postby dave bushell » 07 May 2016, 12:13
The outrigger cover does not cover the speedo drive, it is cut to fit around the speedo drive.
dave bushell
Club Member
Re: outriger cover
Postby ERIC BAYLISS » 07 May 2016, 12:30
Thanks Dave but its still the one I need
ERIC BAYLISS
Club Member
Re: outriger cover
Postby dave bushell » 07 May 2016, 14:04
There are two types. The Brum type which has an extended casting that goes right over the final drive sprocket and the pre-war type which doesn't have the extended casting.
I have two of the pre-war type. One has a split that could be welded and one that is an unpolished casting. Both would need to be cut to fit around the speedo drive. £10 for the split one, £15 for the casting. Plus postage.
dave bushell
Club Member
Re: outriger cover
Postby ERIC BAYLISS » 07 May 2016, 20:13
Thanks Dave,since you said there were 2 sizes I have been looking at pictures and as my bike is far,far from original I think I would prefer the larger one so will probably end up making one in fibre glass and spraying it silver.
ERIC BAYLISS
Club Member
Return to Sources of Supply
Who is online
Users browsing this forum: No registered users and 1 guest
cron
