MDA2 mag/dyno
Users of the forum can post details of where to find useful parts here (other than joining the SOC Spares Scheme of course). Note: The Scott Owners Club Ltd does not endorse, recommend or vouch for any of the postings in this section.
MDA2 mag/dyno
Postby Kevin N Bayliss » 30 Sep 2017, 23:28
Has anyone got a mag armature for the MDA2 mag/dyno, dead or alive, ( I need two ). Also looking for the end cover which holds the cam ring if anyone has one on their shelve not being used. Last but not least the drive gear which goes onto the mag armature to drive the dynamo. Many Thanks Kev
Kevin N Bayliss
Club Member
Re: MDA2 mag/dyno
Postby Barrie » 01 Oct 2017, 09:47
there are a few end castings on ebay, 3hours to go
Also found this,
http://www.ebay.co.uk/itm/Vintage-origi ... Swf4pZy9bi
Barrie
Club Member
Re: MDA2 mag/dyno
Postby Kevin N Bayliss » 01 Oct 2017, 20:47
This is the end cover plate that I'm looking for, the armature on eBay has a damaged end for the points so would need replacing but thanks Barry for looking, Kev
Kevin N Bayliss
Club Member
Re: MDA2 mag/dyno
Postby Barrie » 02 Oct 2017, 19:21
No problem,
Is this end piece a rare item?
Barrie
Club Member
Re: MDA2 mag/dyno
Postby Kevin N Bayliss » 06 Oct 2017, 16:01
It would seem so Barry by the number of replies,
Kevin N Bayliss
Club Member
Re: MDA2 mag/dyno
Postby Barrie » 07 Oct 2017, 09:42
Is your existing casting worn out or missing? As for the armature and the gear I take it your trying to build a mag from bits.
Barrie
Club Member
Re: MDA2 mag/dyno
Postby Kevin N Bayliss » 07 Oct 2017, 11:23
Got it in one, it’s missing and building up one from just a case. Picking up a lathe tomorrow so I’ll prob just make one as Ive got one to copy from. No point asking for Kite forks for a TT Rep as if anyone sells some they will be out of my budget, so they will be made as well along with wheel hubs etc, a busy winter I think. Kev
Kevin N Bayliss
Club Member
Re: MDA2 mag/dyno
Postby Barrie » 07 Oct 2017, 17:44
turn up a the casting, then turn up a substitute shaft( armature ) and then use a modern electronic ignition
Barrie
Club Member
Re: MDA2 mag/dyno
Postby Kevin N Bayliss » 07 Oct 2017, 18:24
Been there on a Silk and a Scott ( Pazon and Boyer ) both caused more problems than it was worth, replaced both with mags and all fine. So thanks for the idea but not again. Besides this mag dyno will be a spare for the Scottish section in case someone requires it for short term use while there's is getting repaired. Kev
Kevin N Bayliss
Club Member
Return to Sources of Supply
Who is online
Users browsing this forum: No registered users and 1 guest
cron
