My bike came as standard with just a selenium rectifier. The battery I guess, was meant to be the regulator. The problem for me with this system is if the bike is taken for a long run, then at best the battery will overcharge and at worst the battery may boil. This overcharging will shorten the life of a battery and spread acid fumes on to the paintwork. I am no electrician so I may be wrong but that is what I think happens. I have junked the selenium rectifier a design that has been about since the 1880’s and replaced it with 6v Alternator Regulator/ Rectifier, this comes wit a heatsink. This rectifies the current to DC and also regulates the current so that the battery does not overcharge.
I was just surprised that after fitting it, the ammeter ceased to work properly only showing discharge. The battery itself is charging fine which has me even more perplexed. I wondered if anyone has a solution.
