Thankyou Eddie,that was most informative. However it raises another question, How do you determine if the springs are worn.At the moment it is very difficult to prise the springs apart using a screwdriver, so they appear to be very strong. I would also like to know how to put the assembly back on to the main casting, Does one have to unbolt the pin,press it between the two springs and then re bolt the pin.
