HOME and how to join › Forum › Open Area › General Scott topics › Gugeon pin removal
Having found my conrods to be on the wrong way around,centre punch mark to outside not flywheel,can anyone explain how I remove the brass cups securing the gudgeon pins.
Mike
Hi Mike,
Why would you want to remove the gudgeonpin pads? Those are pressed in and difficult to remove I would suppose. If you want to turn your rods 180 degrees this will have no effect on the gudgeonpins. Just push them into the piston from the outside.
Hi Erik
I’m still not sure how I remove the conrods to turn 180,does it really make much diference if the rods are 180 degrees out anyway?
Mike
Hi Mike. The original design of Alfred Scott was gradually stretched so that the line of the big end is usually not on the centreline, but a bit wider.
Long stroke rods, if you look at them carefully, are not milled symetrically, but are a bit off centre. The idea was that the centre beam section should not rub against the flange of the crank, so they tried to leave a bit more clearence one side (The inside) There is not a big difference and as long as your rods are not rubbing on the crank as you turn the engine over, it actually does not matter which way they are installed.
If you wanted to turn the rod, you must undo the crankpin screw, remove the outer roller plate, take out all the rollers (A small magnet is helpful).
You must then rotate the flywheel so the rod is at the top of it’s stroke.
If you look down the crankcase mouth (naturally you have the barrel off) you will see two cutouts on the outer side. This is like a “Lay by” parking place for the rod. Hold the rod in these cutouts and again rotate the flywheel to take the crankpin past the “parked” rod. You can now remove the rod. Please note that it was once a traditional practice to replace a rod little end bush, ream it in position and then bend the rod between three pieces of aluminium in a vice to get eyeable alignment with the big end. Twist was dealt with by twisting the rod beam. Unfortunately, this practice rarely resulted in good enough accuracy and often engines would not survive more than 1000 miles. I mention this, as there are rods in use that have been bent so the maximum clearence might not be on the side with the dot.
The obvoius and best test, is to place the rod big end on a flat surface with the little end hangine over the edge. Now look how much space there is under the centre of the rod beam. Now turn it over and check the space under the other side of the beam. Build your engine with the side with largest clearence towards the flywheel. The gudgeon pin is always fitted with the big end to the outside, as this prevents it sliding out into the inlet ports. I hope this helps. Kind Regards Roger Moss
Many thanks Roger for the very usefull and detailed advice.
Mike
