Hi Roger, Result of Rod Round Up.—- 15 (assorted type) LONG STROKE rods.— 11 (various type) SHORT STROKE rods.– 1 only 2speeder rod ,(narrow big end eye).— 1xVeteran rod (narrow big end eye,rollers run on the rod, (no pressed in ring.) Fitted to cast iron piston,with 3 thick rings, 2 rings above pin,1 bellow ,near the bottom of the piston. Phone to discuss your needs etc. Regards Geoff Tel 01446 743159
