Hi all,
A quick question to you all. I’ve got a bike with cylinder wall oiling pipes installed that lead to the end of the cylindrical tube that forms the bottom of the oil tank integral to the petrol tank. At the opposite end of this tube is cable. I’ve taken this lot to bits today but expected to kind a mechanical pump. Instead the cable does indeed operate a spring plunger inside a 3″ long gauze filter, but is not directly connected to the cylinder wall oiling adaptor. Is this correct, does the system just work by creating a small pressure due to the oil being pushed backwards and forwards in this cylinderical tube, or have I got bits missing? I’ve searched but not managed to find an exploded drawing or similar. I also note there are no non return valves anywhere to be seen, is this correct?
Also, the cable from the tank was not connected. I assume it goes to the LH inverted lever?
Thanks in advance for any info,
Richard
