HOME and how to join › Forum › Open Area › General Scott topics › Taper head bearings
The Timken taper head races were damaged in last year’s crash
The 1.0625″ dia inner has long been obsolete
I have been obliged to set up and grind 1.000″ bore 1780 cones out to 1.0625″
Just in case anyone is stuck with this problem, contact me soon as I will revert the machine to other configurations after I finish these.
Kind Regards
Hi Roger,
I react to your new topic about the Timken taper head races. I just need couple for my Flying Squirrel. I guess 27 model has the same once? Im not sure about exact inner size, if there is needed 1 or 1.0625″. I can measure this next week. But I guess its gonna be standard size for all Scotts?
Thanks, best regards,
Martin
It depends on the type of forks fitted. Some long-established bearing stockists may have some in old stock. Usually 1. 1/16″ occasionally 1. 1/8″.
Hi Roger,
this one is with Scott kite forks, 27 model (strait tubes)
M
Hi Roger,
just checked the rings, mine is standard 1″
Martin
The first Scott I had was a 1928 built 1929 model 500cc TT Replica now owned by Ted Parkin
This had Timken Taper roller headstock bearings as standard
These were obviously more expensive than the bicycle type design, but far more rugged.
It is possible that the extra cost caused the use of taper roller bearings to be abandoned in the recession.
The outer “cup” was No 1730 and this has an outside diameter of 2.125″ (2 1/8″) and is still available
The inner “cone” was No 1764X which had an inner bore of 1.0625″ ( 1 1/16″”) and this has been obsolete for many years
I was offered one only old stock cone at a price of £190 and although I realise that modern commerce works on the principle of charging what the seller thinks he can get rather than what it had cost plus a fair margin of profit, I found this offensive.
So I designed and made a special holder for a current cone No 1780, which has a bore of 1.000″, so I could grind it out to 1.0625 to suit the Scott headstock stem.
I then had to change over my grinder to internal working which takes longer than most grinders and grind out the bores of two cones which tool about 2 hours each
So all in all, an expensive job, but I needed these bearings to finish the rebuild of my racer for the Anniversary meeting at Cadwell June 24-25-26
With a few extra refinements, the bike should be better than ever, although the rider is not as fit as he used to be.
This piece is to let it be known that if anybody is really stuck with this same problem, then I have a specially made holding fixture that can be used on an internal grinder to modify the 1″ bore of the 1780 cone to 1/16″ and would loan it out if it helps anyone.
I would prefer not to offer to grind out these bearings myself, as I think that a heavier machine would do the job much more quickly and cheaply
We would love to see you at Cadwell where our club has a stand for the three days.
If you do get chance to come,do bring your bike along to our stand to add to our display
Kind Regards to all.
Roger
Many years ago I had this problem. Fortunately we had a friendly toolmaker that I used for making parts for the factory’s machines where I worked. He was able to grind out the inner race fairly easily. If I remember he used a 3 jaw chuck to grip the inner track. I reckoned that absolute concentricity was not essential as the bearing only moved about 45 degrees.
Velocette also use taper roller head races and I think their spares scheme offers the correct bottom race for £44.50 according to their spares list.
