Forum Replies Created
Viewing 8 posts - 1 through 8 (of 8 total)
  • Author
    Posts
  • in reply to: Novices Beware – 100 ways to break your Scott #8937
    Roy Lapidge
    Slightly off the main subject but, following my Dad’s instructions, I always stopped my Scott by choking the carb. with my gloved hand which left a rich mixture in the crankcases and which usually provided a rapid start next time. Is this procedure followed today?
    Regards.
    in reply to: Old family photographs #8855
    Roy Lapidge
    Many thanks for the ‘photos, most enjoyable.
    May I suggest that you have the ‘photos scanned and enhanced, especially the first image posted. The results are very rewarding.
    Regards.
    in reply to: Engine strip Demonstration #8754
    Roy Lapidge
    It is beginning to seem a long time ago since I last re-assembled the engine of my Scott, AKA ‘Scruffy’, on the kitchen table at my late Father-in-Law’s house at some time during 1955!
    Regards to you all.
    in reply to: langman scott #8054
    Roy Lapidge
    The Bonhams (auctioneers) site has, or had, a detailed history.
    in reply to: 37 years in a damp shed #7741
    Roy Lapidge
    Thanks to the Internet and this Forum, I have been promised that after a period of 51 years, I may in due course, once again sit astride what was my 1930 3 speed Flyer.
    In 1953, my late Father, a Scott ownner at that time, purchased VR **** for me from Slocombe’s of Neasden the price being £35.00.
    When I saw the pictures, ‘Scruffy’ looked vaguely familiar. A PM to ‘bitsa1927’ confirmed that it was indeed my old bike.
    The picture shows yours truly on the Flyer in 1953, the bike as it was when purchased.
    Regards to you all,
    Roy Lapidge
    Roy Lapidge
    in reply to: Boiling Scott #7025
    Roy Lapidge
    Hello Erik,
    I am no radiator expert but I believe that there are variations in the cooling surface area of the ‘waffle’ type radiator cores.
    When your 2-speeder had it’s rad. re-cored, perhaps the incorrect core was used and hence it had insufficient cooling from day one.
    Regards.
    in reply to: Stopping radiator leaks #6418
    Roy Lapidge
    Hello Erik,
    In happy memory of my first motorcycle in 1951, a 1930 3 speed ‘Flyer’, perhaps you may consider trying my method of dealing with minor leaks on a ‘Scott’ radiator.
    Provided you have the patience to get the rad. absolutely dry on the inside by gentle external heating with hot air or similar, and provided that the leaks are at the soldered ends of the honeycomb tubes, try ‘Araldite’.
    Note where the leaks occur, heat the rad. in this area until just too hot to touch and, using a matchstick or similar, apply the ‘Araldite’ which will liquify and be drawn into the porous solder and limescale. If the working area is kept hot for a few minutes, the ‘Araldite’ will ‘gell’ and begin to set. If care is taken, the repairs will be almost invisible.
    Use the normal slow setting ‘Araldite’ which, after mixing, will remain usable for at least one hour. ‘Araldite’ will easily cope with the working conditions of a ‘Scott’ radiator.
    Roy
    in reply to: PETROL TANK COLOUR #6145
    Roy Lapidge
    Hello Eric,
    I quote from a letter from Geoff Milnes dated 25th September 1964 which is my possesion:
    ‘The 1928 Scott Flying Squirrel had purple panels on the petrol tank’
    I hope that the above may be of some assistance.
    Roy Lapidge
