I now have 2 crankshafts and this is the question, above the main bearings there’s a cup as part of the casting which contains a “petroil”? hole that links to between the two brass/bronze driveside bearings, also aligning with a drilling in the mainshaft, further along the shaft is another drilling that aligns with a “feed”to the clutch thrust bearing, the mainshaft is centre drilled and abuts the main drive shaft (the one with the tongue) which is also centre drilled with a feed hole to the bush in the end of the pressed clutch/transmission brake housing, the orignal crank centre is clear and would allow the passage of petroil as I have explained, however the replacement crank appears to be plugged so it could not lubricate beyond the mainshaft, or have I completely missed the point. I have visited Smiths Auto and he was very helpful. I am not familiar with the Wilfred saga Andy
Thank you George
Had an interesting hour @ Smiths Autocycles, but this has now created more questions are there any drawings available of the crank and clutch mainshaft, I wish to clarify the feed arrangements for petroil circulation to acertain if the drillings are correct. Andy
What a beauty congratulations .Andy
Thanks Gents
Sorry for the slow response I used to receive emails when someone replied to a post but this facility seems to have stopped, Ian Parsons responded with the available history, Dave you are correct a 1924 596cc 2 speeder was its original host. My thinking was that if it was a long stroke then Santa may have to contact Roger Moss. Best wishes Andy
I thought Lewis was the instigator in that action & should be applauded for it. Andy
Fantastic! Thank you very much for this wonderful archive as we are now under house arrest I think it be extensively viewed.
I have measured a 7 inch Webb hub and it is 3&7/8ths from the centre of the brake plate to the spoke flange no bearing cover,what forks have you got? If you measure the gap you could perhaps find a set of replacement blades I think Webb hubs are difficult to get and very expensive.
Hi Ray
Assuming you are UK based the procedure is on the flyer that came with the last Yowl. Best wishes Andy
The Clutch Cork Carvery may be able to help
I hope this is what your looking for.
Did Scott make a generator set?
I must admit I was a more frequent visitor to the previous format And I agree that the LE forum is an example or how a forum should function ( I currently have 3 LE’S ) I think the original format of the LE site was created by a IT student but has gone through updates and changes over the years. The douglas one is pretty good also Andy
If you didn’t get to the gathering there is a north west section that meet quarterly, next one is September
If we want to piggyback on to the Velocette event I would suggest we make contact sooner rather than later, I don’t know how much crossover there is with SOC/VOC/NI members. Roger Franklin is the chairman ( thoroughly nice bloke)
Just to put it in to perspective try and have something of this quality designed and manufactured, I have one and it is well made and would be a challange to reverse engineer, I am just thankful there are people like Eddie prepared to help us keep the wheels rolling. 😀
