Forum Replies Created
Viewing 15 posts - 1 through 15 (of 112 total)
  • Author
    Posts
  • in reply to: The Forums will be closing shortly #36655
    Martin Heckscher
    Just for the record, I agree with Olaf, Christine, Graham, and Simon.
    in reply to: coolant ? #36376
    Martin Heckscher
    As I have said before, the optimum coolant for Scotts is Graham’s suggestion of Aphi 11. It contains the corrosion inhibitors that you need for the different metallic components encountered in a Scott’s cooling system, and unlike traditonal antifreezes it is not hazardous, so there is no danger of poisoning children or pets. At a dilution ratio of 40% Alphi 11 with 60% water, or better still distilled water (from a dehumidifier as Leif suggests) it provides protection down to -22 degrees C. I’ve been using it for many years and haven’t had any problems with it at all.
    in reply to: Wanted Connecting Rods #36119
    Martin Heckscher
    Of course that should have been signed Martin, just in case anyone wrongly supposed that I am now going by the name of Marti!
    in reply to: Wanted Connecting Rods #36118
    Martin Heckscher
    Hi Doug,
    I just got back from the Kingdom of Mourne weekend, your original request having dropped in when I was madly busy just before I went. I may be able to help you with rods though I won’t be able to guarantee their condition other than any obvious defects – all are secondhand. Will try and have a look later. Please send me an email so we don’t bore everyone else with this – email address inside front cover of Yowl.
    Best wishes
    Marti
    in reply to: Two-speeder Kick-start part #35780
    Martin Heckscher
    Hi Mark,
    No problem at all. Get back to me when convenient.
    Martin
    in reply to: Two-speeder Kick-start part #35776
    Martin Heckscher
    Hi Mark,
    I’m not sure, but I think I may have a spare. I’m out all day today but will check tomorrow. My email address is inside the front cover of Yowl.
    Martin
    in reply to: A Pile of Junk #35774
    Martin Heckscher
    It looks fabulous Lewis.
    M.
    in reply to: pre monobloc carburettor #35480
    Martin Heckscher
    Hi Chris, I might have a spare carb, but it will take a day or so to go through and find something for you. Send me an email or give me a ring (details on the inside cover of Yowl). Martin
    in reply to: Reduction Gear Wanted #35307
    Martin Heckscher
    Hi David,
    I’m afraid Manfred had my last available reduction gear. It might be worth contacting Graham Moag at the Spares Scheme – I think he has the last of Gerry Howard’s stock, though whether that includes anything complete that might work for you is another matter altogether. Good luck.
    Martin
    in reply to: Reduction Gear Wanted #34879
    Martin Heckscher
    Hi Manfred,
    It is possible that I may be able to help you. Please email me direct: martinheckscher@gmail.com
    Martin
    in reply to: VMCC collaboration, latest Yowl. #33217
    Martin Heckscher
    Ian, I also agree 100%. The SOC has its own unique identity which would be diluted very quickly if we were to become a section of the VMCC.  Many SOC members, including me, are also VMCC members anyway, and this allows us an insight into both organisations over time. I think we are better run than the VMCC. Our membership is steady while the VMCC’s has dipped markedly in recent years. They have also been in deep financial difficulties, whereas our own situation is very stable. I can see advantages for the VMCC in such an association, but none for us. In conclusion, I strongly believe that we should continue to fly the SOC flag and remain independent.
    in reply to: Two-speed kickstart #33076
    Martin Heckscher
    It’s not directly relevant to the questions raised in this thread, but many years ago Ken Lack told me that the decompression lever should always be used when starting a two speeder in order to reduce the loading on what he considered a somewhat fragile part of the machine.
    Good luck
    Martin
    in reply to: Silencer for 1914 Scott #32964
    Martin Heckscher
    Hi Wilfried,
    You might be able to scale some of the dimensions off the attached photo. It’s a shame that the footboard obscures the detail, but you can still see the outline.
    Martin
    You must be logged in to view attached files.
    in reply to: Silencer for 1914 Scott #32962
    Martin Heckscher
    The best photo I have of the stubby little 1914 silencer is attached. It appears from this photo that the silencer was offset from the central line of the exhaust pipe (I hope that makes sense, but it’s not easy to find the right words!), and what at first glance appears to be an end pipe on the silencer is actually the D shaped tube for the footboard mounting. It would be interesting to know what it was like inside.
    Martin
    in reply to: 1929 Scott TT Replica wheel size #32883
    Martin Heckscher
    Hi Martin,
    It is perhaps worth noting that in both the 1929 & 1930 catalogues, amongst the list of extras is the option of 26 x 3.25 (3.25 x 19 in “modern” tyre sizing) in place of the standard 26 x 3.00 (3.00 x 20). This would have cost you an extra 10 shillings.
    Good luck
    Martin
